VA ASI 533 MC - kawa -
J'ai fait l'astrometrie du crop ci dessus pour tenter d'en savoir plus sur le petite galaxie mais ca ne l'a pas fait
Peut-être là, tu auras un début de réponse
https://images.mantrapskies.com/catalog ... /index.htm
To the east of NGC 5993 is an object I\'ve labeled [SP82] 52 which NED lists as a blue compact galaxy but an essential note says \"May be an outlying HII region or companion to NGC 5993.\" It seems to have some faint star clouds around it, especially to the west. So I vote that it is a blue compact galaxy. It may have been somewhat disrupted by NGC 5993 and or NGC 5992.
In the lower left is an object that is somewhat elongated, certainly not starlike that is listed in NED as SDSS J154551.14+405641.1 a quasar and as [VCV2006] J154551.2+405640, a galaxy. Usually, a quasar so outshines the host galaxy the galaxy isn\'t seen. They do list this as a candidate BLAGN (Broad Line AGN). Most quasars are broad line AGNs. But if it is one why is it so dim? It is closer to us than nearly all known quasars. So it may be a dying quasar. None seem to exist in our present universe. It\'s only when we look back in time they become common, They seem to have all died out by about 2 billion years ago though one is known at only a half billion light-years it is a very weak one in which the host galaxy is easily seen. It may be this one is running out of its food supply needed to keep up the output of a quasar.
Le quasar?
Le quasar?
- ouki
Facile @kawa
PGC 3417190 spirale a 16,5.
PGC 2174741 elliptique a 16,47 uhhhhhhhh
Merci skysafari
Merci skysafari
En image, c'est plus parlant
Merci @ouki
En fait, il y a plus de choses qu'on ne le voit au prime abord
Source: http://www.astro-photos.net/CCD/CCD2/NG ... g_ccd.html
Ce champ d'image n'est plus jonché de galaxies plus brillantes, mais montre des galaxies très intéressantes. Les deux plus brillants et les plus grands sont NGC 5992 (au centre) et NGC 5993 (en haut à gauche) à environ 420 millions d'années-lumière. Ils forment une paire physique et interagissent probablement par gravité l'un avec l'autre, ce qui est visible dans la queue de marée de NGC 5992 et l'asymétrie de NGC 5993. NGC 5992 méritait d'être inclus par M. Arp dans son catalogue de galaxies d'apparence remarquable. En revanche, ils ont trouvé leur chemin dans le catalogue similaire de l'astronome arménien Markarian sous le nom de Mrk 489. Le disque de NGC 5993 est orné de deux étoiles au premier plan.
Il convient de noter la galaxie PGC 3417190, située au sud-est de celle-ci, dont les deux bras en spirale sont éloignés et inclinés. Avec la galaxie PGC 2174741 au nord-ouest de celle-ci, elle est à plus de 800 millions d'années-lumière. Au nord de cette galaxie, un faible point de lumière avec une luminosité au-delà de 19 mag peut être vu. Il s'agit du quasar SDSS J154445.09 + 410305.0, qui a un redshift de z = 2,315. Après avoir fonctionné pendant près de 10,5 milliards d'années, sa lumière est tombée sur le capteur de mon appareil photo.
Au nord-est de NGC 5993, il semble y avoir un amas de galaxies éloigné. L'impression est trompeuse car les galaxies sont à des distances très différentes. PGC 2180071 et son voisin sont à peine à un milliard d'années-lumière. Les deux montrent des queues de marée sur les images SDSS et devraient donc interagir gravitationnellement. Cela ne peut pas être vu sur mon enregistrement. PGC 3852573, PGC 3417168 et quelques autres galaxies à l'ouest et au nord de celle-ci, en revanche, sont à près de 2 milliards d'années-lumière. Alors que les bras de la barre spirale PGC 3852573 qui forment un anneau ne sont pas visibles sur ma photo, la queue de marée du PGC 3417168 s'étendant vers le nord est reconnaissable sur ma photo. Après tout, la galaxie, y compris sa queue, a une taille de 200 000 années-lumière.
Il se passe plus de choses sur le bord supérieur de l'image: la galaxie PGC 3417167 scintille au centre de l'image, c'est une spirale de barre de faible luminosité à près de 300 millions d'années-lumière. Plus à l'ouest, PGC 214409, une belle galaxie spirale éloignée d'un peu moins de 450 millions d'années-lumière, est beaucoup plus lumineuse. Et l'UGC 9988 apparaît dans l'image dans le coin supérieur droit.
Merci @ouki
Et ben merci @ouki , il faudra qu j'y vienne à skysafari
Merci @kaelig j'ai tout lu vu l'effort fait pour ressortir tout ça , je me demande ce qu il va rester dans ma mémoire
J'ai shooté pour NGC5993 (sans ROI) champ complet , puis zoomé pendant le stack dessus , la forme de PGC3417190 a attiré l'oeil
Le crop est un peu plus parlant , je suis a chaque fois surpris de ce que l'on peut voir dans mes conditions . Bon ce n'est pas du N&B, pas tres fin , mais ca me VA
... le plaisir de découvrir
Dans ma pratique astro, le "plaisir de découvrir" est le moteur principal. J'aime voir un objet, j'aime le saisir, j'aime partager et j'aime comprendre au-delà de ce que je vois. Ce que j'aime sur "deep sky", c'est que l'objet est fouillé. Pour moi, cela donne de l'épaisseur à nos images et ca rend la pratique beaucoup plus intéressante. J'ai donc pris du plaisir à chercher
- turbojf
Une belle et prolifique première quinzaine d'avril,@kawa , je n'avais pas encore pris le temps de te le dire.
A chaque fois ton hyperactivité est surprenante et aboutie , tes connaissances impressionnantes , ton implication sans faille .
Et un job pas évident pour l'astro .
Dommage que tu sois si loin, tes compétences en informatique m'auraient bien aidée ici .
Merci JF @turbojf , tu ne m'étonnes pas vu les marathons que tu fais , je dois avoir encore une soirée vers le 14 il me semble avec des petites tachouilles , il faut que je regarde si on voit quelque chose sur les stack pour le partage ,j'essaye de n’être pas trop retondant je fais assez cool ces temps ci .
.Il faudrait que je refasse des essais avec le C9 , mais c'est tellement pratique à sortir et rentrer ce petit 150 .
Je précise ma pensée : ça devient trop facile avec ce 150, il faut pimenter un peu la chose avec une focale longue et plein d'enquiquinements en tout genre
C'est bien vrai , je ne sais plus quand j'ai vérifié la colim , les vieux darks , les flats des vieux , la 533 est soudée dessus , fait meme plus la MAP ,
je sort la BoxAir ( boite en plastic ventilée ou tout est dedans , alims, hub en tout genre , et même la place pour un 2eme ordi portable replié ) juste a brancher les câbles qui sortent et je fais quand même la MES sans la polaire
Couvre feu = calme olympien en centre ville , quelques "bougies" autour histoire de ne pas sortir la lampe
Manque les sangliers , à défaut quelques souris et dans la haie dortoir la meute de piafs silencieux en train de roupiller ou me regarder.
Vous essayez de me mettre la pression hein , ca va me stresser je le ressens déja .
A regardez les jours qui viennent , la méteo , la lune
Je constate souvent sur astrometry les petites tachouilles qui ressemblent pourtant bien a des galaxies ne sont pas identifiées
très joli, je trouves que nous sommes de plus en plus à nous laisser tenter par la chasse aux petites taches. Ca doit être le syndrome Mc Burn. En tout cas vraiment bien sympa
J'ai pas trop le choix , je tire d'un trou du cul comme champ à l'Est entre les immeubles , il y a le Lion , Bérénice ,la Vierge de la tachouille à gogo, mais c'est bien ça change des nébuleuses flashies qui vont arriver et puis tenter de connaitre tout le ciel c'est bien .
Pour l’astrométrie j'ai fait avec "Astrometrie.net" , ca ne sort pas tout dans le CP , il faut faire comme les ténors ici avec d'autres outils .
Tu devrais trouver des infos dans le TAG bleu "ASTROMETRIE" ou sur leur post respectif
* Soirée du 14/15 Avril - An02 Covid*
Oui je suis très à la bourre , mais moins de temps pour l'astro ces temps ci , et ça tombe bien le temps n'est pas top
je profite d'un petit répit pour sortir cette soirée surtout orientée Amas pour changer et puis ils sont très jolis et dociles .
Site = habituel de confinement
Matériel habituel AVX - Newt 150 , asi533 , SharpCap , pas de guidage . ir-cut monté - Dark et flats - les crop sont retouchés PS
*IC4479 * - tentative de sortir une petite tache de la PL - 109x16s gain 150/600 .
*M3 * 42x8s gain 150/600 .
*M13* 52x89s gain 150/600 .
*M53* 38x12s gain 150/600 .
*M92* 46x8s gain 150/600 .
* NGC 5466 * 25x12s gain 150/600 .
- Ubuntu
- ouki
Une passion les tachouilles
Superbe Ic 4479 avec la petiote pgc 214309 accolée avec une magnitude indescente et quelques autres aussi d'ailleurs
- f6uhbgf
Bravo ! J'aime beaucoup ta nouvelle présentation , va falloir que j'y pense pour mes futurs post sur Facebook.
Super boulot Kawa
, la présentation est super sympa (ca doit demander un peu de boulot
C'était une première , je n'ai pas insisté en me disant que ça ne sortirait pas plus certainement à tord
J'ai tenté de voir ce que ca pouvait donner une petite chose comme ça perdue dans ce champ , et en consultant toute l'info sur wiki et autre car j'ai attendu 30mn , au bout du bout
@f6uhbgf et @kaelig , C'est pas super car le gars n'est pas top , j'avais déja fait pour M1 .
J'aurais du prévoir le coup et excentrer l'objet pour laisser plus de place au crop qui du coup n'est pas si grossi que ça .
C'est assez rapide , je prends le Save as Seen je recadre l'objet plus quelques retouches ( moches) et je sauvegarde le "crop" en jpg , je mets copie dans le presse papier .
Je reprend l'image de base SaS (png) je redimensionne a 1500x1500 je sauvegarde en jpg et je colle le crop dessus en le redimensionnant ( c'est là que je me rencontre que je n'ai pas assez de place
Et les retouches plus moches que l'origine
Finalement le cote à cote est peut être mieux .
- Tibox
Bon petite soirée courte , le lendemain il faut se lever de bonne heure .
* Soirée du 03/04 Mai - An02 Covid*
Site = habituel de confinement -C.V. EST -
Conditions ciel dégagé , un peu de vent par moment .
Je tente une nouvelle présentation - Copie écran - Et Duo cote a cote Save as seen comprimé et amaigri en dimensions et Crop retouché
En remontant au dessus de Arcturus sur laquelle j'ai fait la MAP
*IC 4343 à 4349 * Dans le Bouvier - Dimension de ic4345 = 0.9' mag au alentour de 14
81x16s Edit>> j'avais fait l'astrométrie mais oublié au passage - Rajoutée le 07-05-2021 .
En dessous Arcturus
*M5* Amas de la Rose - Dans le Serpent
44x8s .
*NGC 5053 * Dans Bérénice - a droite d'Arcturus
29x12s .
*NGC 5426 * ARP 271 Dans la Vierge , le pont a peine visible .
77x16s .
Tout a gain 150/600 avec le 150/750 ASI 533
Ca m'a l'air bien sombre d'un coup là
En dessous Arcturus
44x8s .
29x12s .
77x16s .
Dernière modification par kawa le 07 mai 2021, 11:07, modifié 1 fois.
