Software for combining mono and color
Rickster
Message par Rickster » 04 nov. 2019, 19:08
Is anyone aware of software that will overlay or stack mono (grayscale) exposures and one shot color (OSC) exposures in real (or near real) time? Here is what I would like to do. I have two telescopes on the same mount. One has a color camera and one has a mono camera. I would like to simultaneously take and stack exposures from both cameras/telescopes. I would like to do this because I get the best sensitivity and detail with a mono camera, but mono loses a dimension without color. So, I would like to be able to colorize the mono image using a second telescope/camera.
Message par clouzot » 04 nov. 2019, 19:46
I’m pretty sure SiriL would be able to do that, provided you write the scripts for it.
Message par Ubuntu » 04 nov. 2019, 19:50
Yes... for sure no soft exists at the moment... would certainly need a bit of programing :D
Rickster
Message par Rickster » 04 nov. 2019, 20:06
I understand from searching Cloudy Nights that Pixinsight will do it in post processing. But I haven't figured out what it would take to make it work for live stacking. I am good at building hardware projects and not so good at building software.
Thanks for the tip on Siril. I hadn't heard of that one. I will look into it.
Message par clouzot » 04 nov. 2019, 20:13
I cited SiriL because I know it’s already been used for live stacking, and it also supports preprocessing images (darks, offsets and the such). So I gather there’s a pretty high probability that mixing luminance and RGB is doable before stacking
Message par Steph » 04 nov. 2019, 20:31
It's hard to do it in real time,with each frames, especially if the camera and focal are differents, the processing time would be long.
But it's not difficult to combine a mono and color final stack in Photoshop for exemple. The mono Stack (luminance channel) must have a bigger size (in pixel) than the color stack.
You can also do that in Pixinsight of course, and IRIS, who is good for this job.
If you have an exemple, I can try to make an action in Photoshop, I just need two .tif image delinearized 16it.
Message par Guimby » 04 nov. 2019, 20:43
I've already seen this be done in photoshop, but not in live... Interresting subject!
Rickster
Message par Rickster » 04 nov. 2019, 20:48
I do have Photoshop (CS6, I think) on my astronomy computer. But I have not used it. The computer is built for this kind of work. It is a Dell T7500 workstation with 12 Xeon cores and 72GB of ram.
Message par Steph » 05 nov. 2019, 20:56
Rickster a écrit : ↑
04 nov. 2019, 20:48
It's good with CS6.
Here an exemple with a very simple Photoshop action in step by step mode for you to understand...sorry @Rickster but in french.
Two images, one for luminance with details, and one for color (no need details, only enough colors), not the same size, not the same angle, with a strange sky... but remember, it is necessary to have enough common pixel for a automatic alignement.
and the Photoshop action video
Rickster
Message par Rickster » 08 nov. 2019, 05:21
Excellent Steph! Thank you. I will be giving Photoshop a try.
