Sionyx aurora procédure démontage optique
Message par ouki » 27 mars 2020, 21:36
Juste,pour mettre en sécurité.
https://www.cloudynights.com/topic/6814 ... ry10070367
Glad you got the protective focus assembly off, sorry I wasn't able to be the respondent on that.
The tear down was not with astronomy in mind but was not without a goal either. The main motivation was to see what would come of using some SWIR lenses as well as relay coupling to I2. The latter works exceptionally well but still not sure on the SWIR lenses as I'm waiting for comparable VisNIR lenses. So far a well corrected 400-1000nm VisNIR lens is panning out to be preferable to the SWIR lenses. Also can't stand fixed lens cameras if there an option.
Nothing serious here, just messing around and having fun with it.
Probably no instructional video on the parts removal and not sure on astro photos or videos in either prime or afocal ATM.
If your going to remove the objective, you'll need to first remove the aperture pin connecting the scene selector ring to the lenses aperture ring. The pin is located under a rectangular cap between the fourth and fifth flute of the scene selector ring. That's with the camera lens orientated away from you, just rotate your wrist clockwise to locate the cap, it's held down with a slight bit of adhesive film (double sided).
Don't try and unthread the lens after removing this pin, you'll need to do a bit more. The aluminum cage/sleeve needs to be removed from the back, accessed by removing 4 screws and separating camera head from main body. There are also slots on the crown of the c-mount interface that are filled with adhesive so another reason not to dismount lens prematurely. The adhesive pockets are under the strip of copper shielding tape. It's advisable to remove the adhesive pockets before attempting to dismount the lens, don't get ham fisted on this as the lens will easily spin off once the adhesive is removed.
Be aware theres a bit of copper shielding tape, just peel back and separate only that which is needed to separate the aluminum lens cage and free the lens.
It took about a careful hour from start to completion.
This really needn't be done and don't want to encourage something that could be a catalyst for an action that could damage someone else camera. If your like me and must make an interchangeable camera of the Aurora, then yea, get on with it
:cafe: :cafe: :cafe: :cafe: :cafe: :cafe: :cafe: :cafe: :cafe: :cafe: :cafe: :cafe: :cafe: :cafe: :cafe: :cafe: :cafe: :cafe: :cafe: :cafe: :cafe:
à 12h43
Heureux que vous ayez enlevé l'ensemble de mise au point de protection, désolé, je n'ai pas pu être l'intimé à ce sujet.
Le démantèlement n'était pas dans l'esprit de l'astronomie, mais n'était pas sans but non plus. La principale motivation était de voir ce qui résulterait de l'utilisation de certains objectifs SWIR ainsi que du couplage relais à I2. Ce dernier fonctionne exceptionnellement bien mais toujours pas sûr sur les lentilles SWIR car j'attends des lentilles VisNIR comparables. Jusqu'à présent, une lentille VisNIR 400-1000 nm bien corrigée semble être préférable aux lentilles SWIR. Ne peut pas non plus supporter les caméras à objectif fixe s'il y a une option.
Rien de grave ici, juste déconner et s'amuser avec.
Probablement pas de vidéo pédagogique sur le retrait des pièces et je ne suis pas sûr des photos ou des vidéos astro dans le guichet automatique principal ou afocal.
Si vous souhaitez supprimer l'objectif, vous devrez d'abord retirer la broche d'ouverture reliant la bague de sélection de scène à la bague d'ouverture de l'objectif. La broche est située sous un capuchon rectangulaire entre la quatrième et la cinquième flûte de l'anneau de sélection de scène. C'est avec l'objectif de la caméra orienté loin de vous, tournez simplement votre poignet dans le sens des aiguilles d'une montre pour localiser le capuchon, il est maintenu avec un peu de film adhésif (double face).
N'essayez pas de dévisser l'objectif après avoir retiré cette épingle, vous devrez en faire un peu plus. La cage / manchon en aluminium doit être retirée de l'arrière, accessible en retirant 4 vis et en séparant la tête de caméra du corps principal. Il y a également des fentes sur la couronne de l'interface de monture C qui sont remplies d'adhésif, ce qui constitue une autre raison de ne pas démonter l'objectif prématurément. Les poches adhésives sont sous la bande de ruban de blindage en cuivre. Il est conseillé de retirer les poches adhésives avant d'essayer de démonter l'objectif, ne vous fâchez pas dessus car l'objectif se détachera facilement une fois l'adhésif retiré.
Sachez qu'il y a un peu de ruban de blindage en cuivre, décollez simplement et ne séparez que ce qui est nécessaire pour séparer la cage d'objectif en aluminium et libérer l'objectif.
Cela a pris environ une heure prudente du début à la fin.
Cela n'a vraiment pas besoin d'être fait et ne veut pas encourager quelque chose qui pourrait être un catalyseur pour une action qui pourrait endommager la caméra de quelqu'un d'autre. Si vous m'aimez et que vous devez fabriquer un appareil photo interchangeable de l'Aurora, alors oui, allez-y
Revenir à « Bricolages »
